Hi guys,
I have a THERMALTAKE Overseer RX-I with THERMALTAKE Frio Advanced cooler.
I am cooling a Intel i7 3930K and I am not very happy in terms of cooling when overclocked. I want to upgrade to a all in one (due to convenience).
What would you suggest that will fit this case and actually do you think there is a point.
I've never had a liquid cooled system before.
https://linustechtips.com/topic/930238-aio-question/
I'm not gonna recommend anything, but please note that installing a water cooler in your system will make it louder. :)
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/930238-aio-question/#findComment-11373173
Can you be more specific? What voltages, what temps, etc.
Noctua NH-D15. You won't be able to fit a 240mm radiator in there, only a 120mm. A 120mm radiator seems to me like to little of an upgrade to justify spending money on it.
Well you have the added noise of the pump, which at least for my Corsair H115i is not that bad (only really noticeable in the performance setting (which doesn't really give any performance boost)). Seeing as he has a case with massive fans and probably running his current air cooler at really high RPM, I'd say it's probably the opposite.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/930238-aio-question/#findComment-11373196
