4 minutes ago, hconverse02 said:
Looks alright, what are your goals? Getting a cheaper motherboard or an 8600k/sufficient cooling might be better.
It will be used for gaming and maybe streaming, can you also edit the list to whatever motherboard/ cooler you think is best, not the best at these stuff, i just plugged in some stuff in the part list :P
https://linustechtips.com/topic/929825-need-help-with-build/#findComment-11369081
Ryzen may be a better bet then, https://pcpartpicker.com/list/hP3ZJ8 EDIT: the stock cooler will be fine
https://linustechtips.com/topic/929825-need-help-with-build/#findComment-11369083
CPU: AMD - Ryzen 7 2700 3.2GHz 8-Core Processor  ($289.89 @ SuperBiiz)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  ($134.23 @ OutletPC)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($184.99 @ Newegg Business)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($119.39 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ OutletPC)
Video Card: EVGA - GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($549.99 @ B&H)
Case: Corsair - Carbide Series 275R (Black w/Tempered Glass) ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($95.89 @ OutletPC)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($379.99 @ Amazon)
Keyboard: Corsair - STRAFE RGB Wired Gaming Keyboard  ($109.89 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.99 @ Best Buy)
Headphones: Logitech - G430 7.1 Channel  Headset  ($37.99 @ Amazon)
Total: $2135.21
Generated by PCPartPicker 2018-05-22 21:58 EDT-0400
https://linustechtips.com/topic/929825-need-help-with-build/#findComment-11369094
Total: $2135.21
why would ryzen be better?
https://linustechtips.com/topic/929825-need-help-with-build/#findComment-11369112
extra cores do better for streaming.
https://linustechtips.com/topic/929825-need-help-with-build/#findComment-11369118
