Do the fans turn on? Do you hear any beeps? Have you tried using integrated graphics instead of your GPU?
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/929435-pc-problem/#findComment-11365358
8 minutes ago, Shakirin Sabran said:
yup, all fans are turn on and all lights also. im not sure that, my board don't have integrated graphics, but i try using another gpu but still same. i suspect my motherboard or psu issue.
Tag me next time you reply so I get a notification. How long do the fans stay on for? What are your system specs?
REMEMBER:
OR
CPU - Ryzen 5 2400G
PSU - EVGA 450BT
https://linustechtips.com/topic/929435-pc-problem/#findComment-11365388
Sorry Sir, this is my first time use this forum. the fans will stay on until i turn off the pc by keep pressing on button , my specs:
CPU: AMD FX QUADCORE 4100
MB: MSI 97A-G43
GPU: ZOTAX GTX 650
RAM: 4X2, each different brand
PSU: 500W
HDD: WD Blue Drive 500gb
https://linustechtips.com/topic/929435-pc-problem/#findComment-11365417
MB: MSI 97A-G43
GPU: ZOTAX GTX 650
PSU: 500W
How long has it been doing this? Have you made any hardware changes recently?
REMEMBER:
OR
CPU - Ryzen 5 2400G
PSU - EVGA 450BT
https://linustechtips.com/topic/929435-pc-problem/#findComment-11365423
