Question about Audio Levels between devices.
With my PC, I would plug in my headphones, and they sound just fine, but just a little on the quiet side. Now when I connect the headphones to my iPhone 7, the sound is much louder, with a lot more definition. I am quite confused as to why this is happening. Could purchasing an amplifier for my PC help fix this?
The headphones I am using are the Sony MDR-XB950N1.
Want any Graphic design or Motion design? Hit me up via the Site, or adding me on skype @ NyxeonFX
https://linustechtips.com/topic/928878-question-about-audio-levels-between-devices/
It depends on the sound cards in each of the devices. As long as you can live with it, theres nothing to do. You could purchase an amplifier, but I would think that superflous.
Also, do you get the same effet with other headphones? If this only started happening recently and you really can stand it invest in a soundmcard for your pc.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
Yes the same effect does happen with other headphones.
Yeah. So it's just the difference between your phones and you PCs soundcard. As long as you can live with it, you don't need to do anything.
42
also,
My build:
There's really only 2 variables that control the loudness of a device. You have the output voltage and the output impedance of the device. Output impedance describes how much voltage is lost, and output voltage describes how much you had to begin with. iirc, the iphone is about 1 volt, with negligible output impedance.
A little known trick with computer audio is that installing/configuring the official audio drivers for a motherboard (rather than generic windows drivers) can enable the headphone amp circuit, which can increase the voltage and decrease the output impedance, making it actually louder.
