Alright, so I have a 4790k that shipped to me at 4.0Ghz... I wanted to know if 4.6Ghz was a good and stable overclock. I know that some people can get more and some can get less. I also wanted to know what voltage I should run it at as well as if my North Bridge clock is alright for my core clock of the CPU. I have been stress testing for about a hour without any OS freezing or BSOD.
CPU: 4.6Ghz
NB Clock: 4.0
CPU Core V: 1.202
Temps: 57-66c when stress testing
https://linustechtips.com/topic/927345-is-my-cpu-overclock-okay/
That all seems fine to me, though I'm no expert of the 4000 series chips. I'd say say you're good to go though.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
CPU: 4.6Ghz
NB Clock: 4.0
CPU Core V: 1.202
NO  you should be able to hit 800GHz at .05V
In all seriousness that OC is fine, i see no issues.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
You might even have another 100-300 MHz headroom with only 1.202V and 66°C max at 4.6.
Xeon e5649@4.4 GHz on Asus Rampage II Extreme or Gigabyte x58a-OC (whatever I feel like to set up at a time) , 6x4 GB Kingston HyperX 1600, Gainward GTX 670 Phantom, Samsung 840 Evo 240 GB, BeQuiet L8 530W
You can push a bit more since you've got temperature and voltage headroom. Make sure Vccin is always 0.5V higher than Vcore. I'd try 1.3V Vcore first and see if the cooler handles it.
Desktop benching:
