 when my computer turns off it's displays only one (have 3) turns back on when i get back. i have to unplug then replug the displays to get them working again. Windows messing up? the display that turns off are random (my laptop display does not turn back on when lifting lid/pushing powerbutton sometimes)
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
https://linustechtips.com/topic/927259-fix/
maybe drivers?
i'd check if your drivers are up to date, if they are, and you are experiencing this same issue, maybe try reverting to an older driver revision, to see if that driver does the same, if it still has this issue, you can fairly certainly rule out drivers to be an issue.
if drivers might not be the issue, i'd check the settings for your displays in the Nvidia Control Panel (only if applicable) and Windows Settings
https://linustechtips.com/topic/927259-fix/#findComment-11345766
