Though I admit it is a fairly cool idea, I see this having two major problems:
1- If you were to have just a block of ice, there would be no way for the air to pass. Maybe use ice in a radiator instead or something of the sorts?
2- The easier of the would be the fact that ice melts, though you could probably have a drain somewhere between the ice and the pc.
All in all still a cool idea!xD
https://linustechtips.com/topic/926172-dry-ice-cooling/#findComment-11334980
Cool idea, you're basically feeding cold air to the case, so while you may gain a few degrees, I think condensation may form at some point so you'd need to take some precaution. Just something to keep in mind.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/926172-dry-ice-cooling/#findComment-11335008
