my laptop used to run windows 10 it run into a problem and i wanted to try something new so i used a program called rufus to load mint cinnamon in it but when i try to install i have a couple of issues I dont know how to partition and i dont want to have any data btw the hdd is 1 tb so i kind of watched a couple youtube videos but after all the hardships and i click install it shows like the partition table format in use so it wants me to do something that i dont know so can someone please help me install this it would be sweet of you
Thank You
https://linustechtips.com/topic/925928-need-help-installing-cinnamon-mint/
2 minutes ago, p13 said:
You chose "Something else" probably, which is why it is showing you the partition table.
Go back.  The option should be there.
It will auto-partition for you.
should i click to install third party thing it says something like turn off secure boot and asks for a password
The third party thing is to install things like flash and mp3 codecs and whatnot, doesn't hurt to turn it on.
Turning off secure boot is nice, but not required.
It is a bit of a hassle, as it will ask you to enter a password, and when your machine reboots, it will annoy you by saying things like "enter the third letter of your password" a couple of times over.  But this is only one time.
i didnt switch it off and hit next it gave me options like
Erase Disk and Install linux mint
Encrypt the new linux mint for security installation
use LVM with the new installation
something else
i used something else in the past i followed the youtube video but it didnt help me at all
something else
Well ... click Erase disk and install linux mint
it shows like
If you click erase , the listed below will be written to the disks. Otherwise, you will be able to make further changes manually
Warning: this will destory all data on any partitions you have removed as well as on the other partitions that are going to be formatted
The partition tables of the following devids are changed:
the following partitions are going to be formatted
partition#1 of SCSI1(0,0,0)(sda) at ESP
partition#2 of SCSI1(0,0,0)(sda) at ext4
partition#3 of SCSI1(0,0,0)(sda) at swap
should i continue?
it shows like
should i continue?
Yes.
If you want to erase all data on the drive, then this is what you need to do.
The first partition is for your EFI firmware, so it will boot.
The second partition is your main partition where all of your data and the OS itself will live.
The third is swap.
Again, you will lose all of your data, I assume this is what you want.
12 minutes ago, p13 said:
Yes.
The third is swap.
it says the installation is complete now do i pull the pendrive i used as bootable pendrive or should i keep it plugged in and restart?
When you click restart, it should tell you something like "remove installation media and press enter" in the console (text only).
So first click restart, then wait for that message, remove the pen drive, and press enter.
it didnt say anything like that the cursor rotated for a while and while restarting it said
image failed to verify with
access denied
5 minutes ago, p13 said:
Shut off the machine, pull the pen drive, turn the machine back on.
In that order.
it gave options like
1 ubuntu
2 windows boot manager
3 ata hdd:wdc
4 pci lan efi netowrk
5 pci lan efi network
but none of them work like when i press them they show the same old error
image failed ti verify
acces denied
1 ubuntu
3 ata hdd:wdc
acces denied
Did you have ubuntu installed before on this laptop at some point?
If none of them work, i guess the install stopped before the bootloader was written.
Try again with choosing the disable secure boot option.
i never did maybe the store ive bought this had that installed but they gave me with windows 10 when i bought now idk what to do
