So without doing anything other than turning my pc on my computer has gone from stable temporature to jumping from 30 up to around 60 (max recorded was 68)
image.png.b25895da98f0d8ecef12808cf751819e.pngimage.png.02fafb73e6720a3a5188f5db8bdbd9ce.png
i would just like some suggestions as to what could be causing something like this as im just letting the computer idle in the screenshots
specs;
I7 6700k
corsair h100i GTX
16GB corsair dominator
gtx 1080
Asus Z170-A
if there is any more info you want just ask, thanks!
https://linustechtips.com/topic/925888-cpu-temps-suddenly-erratic/
specs;
I7 6700k
corsair h100i GTX
gtx 1080
Asus Z170-A
What process has actually been causing the spikes? It's hard to give you a recommendation based purely on a graph of temperatures. If the machine was fully idle there'd be no spikes, so there has to be something running in the background.
nothing i can see there that is out of the ordinary
You'll get a better indication if you run resource monitor instead of task manager - on the CPU tab, you can sort by "Average CPU" which means you can leave it open, go afk for 5 mins and come back to see what process is using more cpu on average. Task manager only shows you cpu usage right at that very moment, and if it's a background process causing the spikes it may be sleeping while you do stuff with your machine.
Keep your temp monitoring open at the same time too.
Is the water pump working?
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
