Hoya!
I'm looking for software that will allow me to stream audio from my Mac to my PC over LAN. Both computers are connected to lan switch. I found many different software but all of them was single OS only, so i hope maybe someone here is familiar with some crossplatform software. Thanks!
https://linustechtips.com/topic/925553-audio-over-lan/
Audio in what way exactly? Music? If its music where you want to use library on one PC, you can do it by setting up UPnP server. On Windows you can do it quite easy with Foobar (addons might be required) and then access with another media player with UPnP support. I've have this kind of setup between Windows, Linux and Android.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/925553-audio-over-lan/#findComment-11332266
