Hi, I'm a noob when it comes to code but I'm currently doing some online food safety courses and have spent 8 hours waiting for timers to press next on presentations and I'm not even 50% of the way through. Tried googling and no one else seems to have posted doing it but I've found videos of people changing code on other courses but changing the similar sort of code didn't work for me. In summary I want to know if it is possible to bypass the wait times so that I can finish the courses and not get the sack and focus time on college instead and if so how.
Thanks.
https://linustechtips.com/topic/925365-online-course-bypass-wait-help/
2 hours ago, Technicolors said:
the timers could be handled server-side
If they are not really much hope, unless you had multiple accounts to rotate.
Without the website and access to it not really anything we can do to help
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
I mean.... isn't food safety kind of important?
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
I'm really starting to think that, but I think it could be the text to voice having to finish maybe but not sure how to go about that. The website is highfield e-learning but you need a staff login, could I send the inspect element code to someone to have a look?
I've done my food safety level 2 qualification this is just repeating what I already know now and I've spent 10 hours and I'm barely through half of it. Would like to be able to get on with college work instead really..
Then you should talk to your lecturer, if they don't listen then go to the head of the department.
If you can prove you already know it and that doing this is harming other subjects they will let you skip it.
I did this in a html class I was forced to take.
