so i recently got a new pc. motherboard is z370p d3 and it has 3.0 usb ports
whenever i try to boot my pc it says i don't know why . i tried everything yet nothing works. can someone help me and tell me what the problem is
NVM. I fixed it by updating my bios version. used windows 10 though, I have yet to try windows 7
https://linustechtips.com/topic/924937-problem-formating-my-pc/
Just now, Lenovo1984 said:
What CPU do you have?
i5 8400
Just now, LogicWeasel said:
That isn't enough information to help you.
What device are you booting windows from, and what device are you trying to install windows on?
Also is your motherboard set to UEFI boot or Legacy (BIOS)?
usb I tried win10 and 7. it has both options atm its uefi
https://linustechtips.com/topic/924937-problem-formating-my-pc/#findComment-11323243
4 hours ago, GrizzlyBear0 said:
Windows 7 and 8 don't officially work properly and get updates on 7th and 8th gen Intel CPUs, along with Ryzen. It's very common knowledge.
https://linustechtips.com/topic/924937-problem-formating-my-pc/#findComment-11324092
On 5/8/2018 at 2:30 PM, GrizzlyBear0 said:
i5 8400
Yeah but are you installing to a Standard 7200 rpm hard drive, or SSD, or other?  (it's very important to note what it is if it's "other" because that could be half the problem).  Is it attached via Sata, M.2, or PCIe?
https://linustechtips.com/topic/924937-problem-formating-my-pc/#findComment-11326848
