My current system has:
Gtx 1060 6gb
i5 4690k (stock)
MSI b85m-e45 (doesn't support overclocking)
12gb ram
I am looking into selling my gtx 1060 for $250 and buying a GTx 1070 Ti (or a 1080)
I wonder if this is a good upgrade, or if i should upgrade something else with my pc first.
https://linustechtips.com/topic/924836-advice-for-upgradeing/
Gtx 1060 6gb
i5 4690k (stock)
12gb ram
Personally, I would upgrade mobo+cpu first, because I think there may be some throttling from the older cpu, im not exactly sure tho.
i like trains 🙂
https://linustechtips.com/topic/924836-advice-for-upgradeing/#findComment-11322068
Gtx 1060 6gb
i5 4690k (stock)
12gb ram
Why do you want to sell your gpu and get a better one?
https://linustechtips.com/topic/924836-advice-for-upgradeing/#findComment-11322105
When considering upgrading, you need to ask yourself what you really need/want for your system setup. Instead of buying a new graphics card when your current one does the job, look at your mice, keyboard, monitors, chair, desk, etc. and see if you can upgrade your setup in a more worthwhile way.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/924836-advice-for-upgradeing/#findComment-11322310
nah, im fine on the setup part, i just want more performance xD
https://linustechtips.com/topic/924836-advice-for-upgradeing/#findComment-11323175
Sort of like asking "should I get a bigger hammer or screwdriver?" Without knowing if you are going to be using screws or nails, it's a pretty difficult question to answer.
https://linustechtips.com/topic/924836-advice-for-upgradeing/#findComment-11323254
