Everything started after the latest Windows update.My microphone was not recognized by the PC and after searching online for fixes, re-downloading latest audio drivers,installing etc still nothing changed.I  was ready to sent it to warranty to be fixed or replaced. Today I played some CS:GO (obviously i can't use it but was still plugged in), something happened.While wearing the headphones and with mic on I can hear if i tape on keyboard, clap, everything with less than a 1/2 second delay. It's a little weaker than normal but is something.It continuously recording but the signal is not going forward.I tried launching audacity, when recording the error appear saying "Error while opening sound device.Please check the recording device and project sample rate.I checked if it's plugged correctly etc.It is a lower end mic branded Somic Danyin DM-028.I don't know how to fix it, if it is a hardware or software issue.Any ideas?
https://linustechtips.com/topic/923836-microphone-acting-strange/
Go into your Windows sound options from the little icon in your task tray. Recording devices, right click your microphone and select properties:
Is "Listen to this device" checked? If it is, turn it off.
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
Just now, TitanMan97 said:
Now the echo is gone but not responsive.
That's strange, are you sure it's not muted in-game then?
14 minutes ago, TitanMan97 said:
The odd thing is that I can not use it, no games, can't record with audacity, random sites where i can check if it's working are giving me errors.I can't use it on other devices right now.
have you tried it on another machine?
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
7 hours ago, TitanMan97 said:
I will try on other PC.
How did it go? you get it working on another computer?
bulgara, oh nono
Multipass
