Please see attached video.
I don't know what is the cause of this problem.
I'm not sure if it's a GPU problem.
But the problem occured many times, same spot, same color, all same. When I'm opening the computer first time of the day, I get that display then it suddenly disappear. But when I try to restart or shutdown and open it again, the thing is gone. It only appears when windows logo shows up.
I tried to stress test my GPU for 15mins-30mins and I didn't see any problem like that.
Can anyone help me of this? If it's the GPU then I can easily RMA i've been using it for only 3 weeks now.
The max temp of my GPU on high load is 75C, I don't know if this is relevant tho.
Any help will be much appreciated. ☺
VID_20180504_200457.mp4
https://linustechtips.com/topic/923502-i-need-help/
RMA that GPU. I'd say that's the problem.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/923502-i-need-help/#findComment-11309258
6 minutes ago, JoshuaA9088 said:
It does appear to be a GPU issue. If I were you I would RMA.
I tried to stress test my GPU after seeing that problem and I didn't see any problem.
That problem only occurs when windows logo showed up when I boot.
https://linustechtips.com/topic/923502-i-need-help/#findComment-11309284
