Need help with CSGO ranking.
Solved by NelizMastr,
17 minutes ago, Zaki_Owais said:I actually meant my next rank.I know I dont need to play 10 matches again.
I meant to rank up again do i have to win 10 matches or 3 cuz I had won 7 matches continuously before I lost 1.
Thanks Though!
Ah I get it now. No there's no need to win 10 in a row for a next rank. You could even rank up after just 1 or 2 wins in a row. Getting carried by a team will make the process take longer, but if you're often top fragging chances are you'll rank up much quicker. The other way around, if you bottom frag and lose often, deranking happens rather quickly. You could even top frag and lose and still keep your rank. There's a lot of variables here
