Hey guys, I used to follow the graphic card scene heavily but I haven't had time to research the new graphic card series from either Nvidia or Radeon. I know that Radeon cards prices jumped because of the bitcoin miners, but is there any expected time the prices will begin to come back down? For example, the 280x is $400 right now, what was it before the spike?
Thanks guys :)
https://linustechtips.com/topic/92325-expected-drop-for-amd-products/
Thanks guys :)
No no one knows how long it will stay at that price, it was around $300-$330 before the price increase.
Wow, definitely will be picking one up to crossfire if it's only $300. Hopefully it's not too long till they come back down in price..
Do you already have a 7970? If you don't you're better of with a 290 or 290X
If you do, sell your current 7970, and buy a 290(X) or Nvidia equivalent.
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
I've got a 7970 GHz right now, the majority of people are saying to crossfire it with a 280x, saying it will out-perform a 290x.
It will, but it's usually better to have a single card setup.
Crossfire still has... issues.
http://www.techspot.com/review/639-triple-monitor-gaming/page10.html
I don't think you will be gaming with 3 monitors but:
We typically avoid recommending multi-GPU setups with mainstream cards because we'd rather buy a higher-end single-GPU solution and avoid the pitfalls associated with SLI and Crossfire. Many games ship with poor dual-GPU support and require special attention from AMD and Nvidia, and with lower-end multi-GPU setups, performance can be pretty lousy when only one graphics card is being tapped.
You can sell your 7970 now and get a 780 Ti. That would be pleasant.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
