Im gonna upgrade to a new pc very soon, and im gonna use my old ssd and hdd in this new build...
Am i just gonna have to install the new drivers and stuff or do i need to do something more ?
Current specs: GTX 1060 3gb
                       i5 6400
                       16gb ram
                       GA-h110m-h ddr3
New specs: Rx 580 8gb
                   ryzen 1600x
                   16gb ram
                   msi x370 gaming pro carbon
https://linustechtips.com/topic/922905-is-this-gonna-cause-a-problem/
You'll want to sysprep your drive for the Windows drivers, and then use DDU to uninstall your GPU drivers. Then you can reuse your SSD and HDD.
and also, do i need to uninstall my gpu drivers before building the new pc or do i need to do all this after i build it
2 minutes ago, Carbide X said:
systemrepare ? what does that do ?
sysprep essentially makes your drive ready to be used in another PC so it doesn't load incompatible drivers.
I'm pretty sure you can do it after building, but I personally would do it before building.
Uhh... Are you BUYING this 'new computer'?  Cause it's kinda a lateral upgrade compared to the old one. o.O  Like if you're going in full price on this 'new computer' it's going to be marginally better than the old one and not justify the costs of a whole new platform, CPU, and graphics card.  If it's a gift or handme down, I guess.  But for a purchase for upgrade this is a HUGE waste of money in terms of what you will spend vs how much better it'll perform.
You'd do a lot better to JUST put all the money into a new graphics card and keep the rest of the system.
i already bought most of the parts hahah, im waiting for the other ones, my current build isnt that pretty either, this build is gonna be more powerfull and more aesthetic
4 minutes ago, Lenovo1984 said:
If it's Windows 10, you don't need to do anything. Just move the drives and you should be good.
You sure ? @Crunchy Dragon thoughts ?
In my experience, you should always sysprep a drive before moving it to another system with the purpose of booting it. The easier way is to just reinstall, but if you have data you care about, sysprepping is usually the best way.
you might need to reactivate windows if it's an OEM key so keep that in mind.
Might be a good idea to bind your Windows key to your Microsoft account to be safe:
https://support.microsoft.com/en-us/help/20530/windows-10-reactivating-after-hardware-change
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
I read the link and it said
Note
If you've already added your Microsoft account to your device, you'll see Windows is activated with a digital license linked to your Microsoft account on the Activation page
Which in my case it is, so i think im good, right ?
Note
Yeah, if Windows is telling you it's all linked up, then it should be all set to go. Bob's your uncle.
26 minutes ago, Carbide X said:
Not sure what you meant with bob but tnx hahahha
Sorry, it's just kind of a phrase. "Bob's your uncle" is like "You're all set" or "Good to go".
