I need some overclocking help
By
Eldon3379
in Troubleshooting
in Troubleshooting
Solved by nsyedhasan,
Sorry to say but, you don't have a great overclocker. The voltage you are running it at is too high. I would say the max voltage you should run it at about 1.3V. Having a high voltage means that your chip may not last as long.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases2 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
