after effects help
Go to solution Solved by Tahmidc,
I think what you are talking about is tracking.
Try this: https://www.wikihow.com/Motion-Track-in-Adobe-After-Effects
Okay so im gonna try to make my question as easy and understandable as possble...
You know on snapchat if you recorded a video and you place a photo on the video and you hold it with ur thumb that this picture stays on that frame of the video.
for example: (0n snapchat) I recorded a video of my friend doing something and i place a picture of him making a weird face on his face, if i hold the picture it will attatch to his face and it keeps following it
how do you do this on after effects
https://linustechtips.com/topic/922418-after-effects-help/
Its called motion tracking. I have used AE built in tracker and that works fine for easier shots. However for more advanced shots I have found Cinema 4D’s tracking tool to be really good for.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/922418-after-effects-help/#findComment-11299906
