upgrade Help upgrading prebuilt HP PC
19 minutes ago, Edwardk326 said:change the case.
the heatsink (CPU cooler).
the power supply.
and the graphics card.
Because it is a prebuilt system it may have mainstream parts, i.e i7 920, but the motherboard could be a different form factor. This also means that your PSU's connetors will also be most likley differnet. So if this is true then:
You can not change the case, because there will be no third party ones that support the same sized board as the one you have.
The heatsink could be changed, as your i7 920 could have normal mounting screws etc. but this could be wrong.
Your powersupply is also probably a no if you have propritry headers on the cables.
You should be able to change the graphics card for something a bit more beefy. You probably want to get a low power one without any extra power connectors as your PSU may not be able to power it otherwise.
If you upgrade your GPU now to like a 1050 or something, then get a whole new system, with up to date parts, you could bring the GPU over and that could be a solid upgrade path for you.
