using internal dvd drive externally?
Go to solution Solved by JohnnyGrey,
I don't think two USB ports would power the drive properly, but I see no reason why the computer shouldn't automatically recognize the drive when plugged into the USB adapter.
What I don't understand is why don't you just install it internally? Even if there's no room, have it sitting outside the case with it plugged in internally. As long as it sits flat or vertical and doesn't get bumped, should be fine.
so instead of making a new post decided to re do this one since its sum what related. my question is can i use my old internal dvd drive externally is there some sort of universal driver or something like i plug it in with this usb to sata and the drive opens and closes and it allocates a drive letter on my pc but when i put in media it doesnt show up like my gta disc lol heres some pics of it also i got the usb thing of ebay originally for xbox slim hdd which it works for that in xbox modding programs and the drive worked fine in my old pc when it was plugged in internally.
post-1006-0-69082000-1387802000_thumb.jp
post-1006-0-50822300-1387802044_thumb.jp
it has 2 usb plugs for power btw u can only see one in the pic
https://linustechtips.com/topic/92143-using-internal-dvd-drive-externally/
Get an external usb dvd drive?
read op
If you make an iso file and mount it as a virtual DVD it's going to be exactly the same as if you had a physical DVD.
Windows 8 can mount iso files out of the box, for windows 7 you can use something like daemon tools
op says "Also really cbf putting on my laptop extracting the files then transferring it to my external hdd then moving it to my desktop then get a no disc crack lol."
First world problem.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
i have an SG09...
Ok i love you right now it was a power issue i used my external hdd enclosure part and now it works!
