Okay so i have a PlayStation  4 and i have a headset with mic. I often play with my friends and i want my girlfriend to be able to here and talk with us. I bought  a headphone splitter and it works but i can no long talk when i use it. Is there anyway for us to both listen an chat?
https://linustechtips.com/topic/921254-headphone-audio/
Headphones imply no mic, so your splitter won't be able to carry the mic signal. Probably have to find a headset splitter. But definitely read details before purchase, as a headset splitter could also mean splitting into separate audio and mic ports like a PC typically has that isn't what you want.
Alternatively, you could do audio on your sound system and hook up some mic for you two to use. The Playstation Camera has mics for example. No idea how good that is and what kind of issues you'll get from your friends who may pick up some of your game audio depending on the setup.
https://linustechtips.com/topic/921254-headphone-audio/#findComment-11287022
This is a limitation of the splitter that you purchased. Could you let me know which headset you are using?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/921254-headphone-audio/#findComment-11287023
11 minutes ago, Jdip97 said:
Hyper x stinger
You might be able to get away with a cheap USB audio card for your girlfriend's set of headphones. Please note, however, that you cannot have two active audio inputs on the same system.
Desktop
Homelab
https://linustechtips.com/topic/921254-headphone-audio/#findComment-11287095
