26 minutes ago, redking619 said:
No it's just turns on for like 3-5sec then turns off nothing shows up on the Monitor.
sorry for taking so long to reply I was having Trouble getting on this website.
Still I think that its the PSU. If you have a spare PSU then try it.
https://linustechtips.com/topic/921087-pc-keep-restating-help/#findComment-11285954
Dude no need to give it in a shop. You can do it yourself if you didn't apply any thermal paste to CPU apply some and see (I'd suggest using a nonconductive thermal paste like artic MX-4). If it is still restarting over and over again then clear the CMOS on some motherboards you have a button which you press (on others you need to short the pins together your motherboard manual will tell you which pins to short and where are they located). If it still doesn't work and your computer keeps resetting then it helps to press the reset switch on your motherboard which will reset everything.
note to self: it is completely normal for a computer to sometimes restart a couple or a few times after a bios update. You should completely calm any abrupt power loss or you pressed the reset or power off switch during a BIOS update can and will brick your motherboard so please be careful.
Motherboard: Asus Z97-Deluxe, Processor: Intel i7-4790K@4.3GHz@1.150Volts, GPU: Asus ROG GTX980 Matrix (with a NZXT G10 bracket and a nzxt x41 AIO liquid cooler), Ram: Kingston HyperX 32GB 1866MHz CL10, PSU: Corsair Hx1200i, Storage: 1TB Seagate SSHD with a Kingston HyperX Fury 240GB SSD, Display: BenQ XL2411Z, Keyboard: Corsair K70 RGB, Mouse: Razer Deathadder chroma.
pc part picker list:
https://pcpartpicker.com/user/hu0210/saved/#view=qHK6XL
https://linustechtips.com/topic/921087-pc-keep-restating-help/#findComment-11289465
