I'm trying to find a decent Liquid Cooling Case, preferably a Mid-Tower case, I'm liking the Cooler Master HAF 912 Advanced but im not sure if it would be the right case, right now I like NZXT Liquid cooling parts like the Kraken G10 and Kraken X60. Let me know what you guys think, I would prefer if the case has good air flow and a big side panel window.
https://linustechtips.com/topic/92095-good-liquid-cooling-case/
NZXT Phantom. Corsair 300R
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1241290
The Arc Midi R2 would be a good option I believe, or you could even go mATX with the 350D and still fit a 240 rad for CPU and 240 rad for GPU :)
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1241333
the HAF912 is not a good water cooling case. will not accommodate the X60 without
case modifications.
big side-window is AIR540, 750D, a lot of the NZXT cases.
water cooling with options, air flow and window is fractal design arc midi.
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1246030
case modifications.
what modifications would have to be done??
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1246472
change the case!
honestly, the roof is not ideal for any AIO, most have the rad installed and the
fans externally mounted (EEEWWW). the 912 has been around for years and
i'll google images of water cooling for the 912 and it is the same pix, very few.
i like the case and have always wanted one, but it just wasn't feasible to redo
the entire chassis.
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1247281
change the case!
the entire chassis.
alright what about without the water cooling, im just really picky with cases and the 912 advanced is the one im kinda set on, I do also like the Cooler Master HAF 922 Black Edition the only reason im not set on that one is because it doesn't have a side window, would that be difficult to add in a side window to that case??
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1248818
for air cooling they'd be fine. just fine, not great. it'll take some better fans that the cases
come with to make the cooling better/best. but, when you increase the fans in those cases
they tend to get "tinny" and airy in noise and seem to be "loud" cases. if they do it for you,
then don't hesitate, but there are newer cases that might not have the aggressive look
of those, but are far better in air/water cooling. for under $100 the Fractal Design Arc Midi.
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1249351
alright thank you! and one more thing, the top of the case has a 200mm fan slot but can hold 2 120mm fans, would i be better of with 1, 200mm or 2, 120mm?
http://pcpartpicker.com/p/2p8lO heres the parts im interested in
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1249371
looking at the parts build, noice. i just scored another 8350, but this time with the giggy UD3.
i liked the Crosshair, but wanna do something different with no red in the theme (LOLs).
personally, id use the 120mm fans over one big 200mm. you can throttle the 120s down
with a bit more granularity. and if you go for the 2x 120 in the front, use the SP fans for
the intake. pulling air into the case through a filter/chassis is a performance killer. the added
static pressure promotes more flow. and if you can swing it, use the PWM fans. they can
volt under 500rpm.
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1249407
volt under 500rpm.
alright thanks man!
https://linustechtips.com/topic/92095-good-liquid-cooling-case/#findComment-1249441
