Hi there.
I helped my friend to upgrade hes pc for gaming on really tight budget from fx4100 to i5 3470 plus ssd. I bought parts the 3470, 8gb 1600 corsair ram and Ga B75m D3v mobo with sandisc ssd, and stock cooler from 3770k. Ive had same gpu as him around, gtx 660 and I instelled all drivers etc with no problems... w7 updatee etc... However I was testing in games and i had random crash (i could hear in headphones brrrrrr) everything froze and pc restarted with no error message or bsod screen. Happened few times so ill checked whats up with ram and timing and I enabled XMP. I then tried all the stress tests and mem tests and was checking temps... cpu never hit 55c and gpu was ~75ish and I could get the pc to crash again... So I assumed the xmp fixed it as mybe ram was undervoltaged or w/e. Packed it up and sent to my friend and whoaa the problem is back and the xmp is enabled. So I could say it is not psu/gpu/ram fault. The restart is by far triggered by alt-tabbing out of game ... Crashes with no warrning. I told him to try different ram setting/cpu minimum state 5%/save windows error code(that turned up 0x80041003 but i guess is not related and software cant rr pc like that)/turn off automatic restart and some other stuff and no luck! And I feel like di**head now :/
My thoughts is that it is motherboard about to die i hope im wrong as them are expensive as hell ...
Any help will be useful.
Thanksq
https://linustechtips.com/topic/920114-cursed-parts-help-please/
18 hours ago, sviestish said:
Hi there.
Thanksq
Check your reliability history for clues.
Hit start - type reliability history - open it - double click on any red errors that happened while the crash happened - copy and paste what they say here.
Look for any yellow warnings of failed updates and post them here the same.
I guess you might have to get your friend to do this bit since he has it right now.
Got this... I told him to try DDU and see what happens ... I guess every restar had this error on ... he didnt show me any updates ... Ill keep posting if fixed. Thanks dude
Yea, DDU is a good suggestion since that code 117 points to a problem with the graphics card.
It could be a dead card worst comes to worse..
but it's not exactly one that'd be too expensive tor replace anyways.
Honestly, I'd get a gtx 970 or something for about 150-200 bucks used on auction if the card ends up dead.
A bit of an upgrade to a generation that's a lot less likely to die and will even support VR not the CPU does :P Actually, yea maybe something a bit cheaper if you can find a good price. No point in pairing a 970 with that CPU. Maybe a 1050 if they want a newer one after this debacle.
Yeah but 970 cant be on tight budget=£170 BUT cant be dead gpu cos I had same crashes when tested and I had evga gtx  660 and he have asus gtx 660... cant be we both had two dead cards and hes pc before upgrade was fine and the one Ive took my card too. But hopefuly DDU will help...Ill update when smth new happens.  Fingers crossed.
Okay, yea that's good news. Most likely not dead.
If DDU doesn't help, try a windows reinstall next.
None of us like doing it, but it's a quick way to rule out anymore software issues.
I have seen this before once and they did two things and I am not sure which was the solution, one was to boot with only one stick of ram in and then later on reboot but with both (you could try a program like memtest to see if it is the ram) They also ended up reinstalling windows from scratch which ended up leading to some other problems. I would try the ram first as that is a lot easier to do especially with memtest.
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
Yes if you read my first post... I done memtest for 3hours and there is only 1 ram stick... Will tell him to try other slot...cheers
  • 3 weeks later...
