So I want to get a better gaming experience by upgrading but I don’t have money. I was wondering becuase  my cousin is old and maybe it’s holding my gpu back so I was think of getting a pentium G4056. Is this compadable with my motherboard and ram if is is it worth it? Thanks.
Specs:
OS- Windows 10 64bit
CPU- AMD FX-4300 quad-core (3.8ghz)
GPU-Radeon RX 460 2gb
Memory- 8gb DDR3 ram
MotherBoard-GA-78LMT-S2
1TB hard drive
450 Power Watt Supply
https://linustechtips.com/topic/919240-need-help-with-upgrading/
you would be better off going with a ryzen cpu rather than the pentium, imo also you can as the pentium is from intel and the current cpu is from amd, intel uses the lga(pins on the motherboard) socket and the amd uses the pga(pins on the cpu) socket. in addition to this, the ram and motherboard would be upgraded meaning that this is not very cheap.
if you went with a ryzen you can find a r3 1200/1300/x for a cheaper price and a b350 motherboard to overclock it for more performance, these chips are quad core not "hyper threaded" cpu's so that means that they have 4 actual cores inside compared to the pentium's 2 cores and 4 threads
however upgrading to any of these 2 means that you need need ram and motherboard, right now the ram is pretty expensive and for ryzen faster ram is still ideally better, for the intel CPU it isnt as dependent on the ram speed. the best ram speed for ryzen is 3200mhz if you can run that ram speed.if not try to get as high as possible
so i also just chekced the bottleneck, and no, the gpu is low end enough that the fx can run it without choking it so i dont think youd need an upgrade.
I edit my messages often. Please refresh for the latest message.
I am not always on the same thread. Tag or Quote me to get my attention.
Remember to Mark the solution to help others in the future.
SFF
CPU: R7 5800x3D
Motherboard: Asus ROG Strix x570-i
RAM: Corsair vengeance 64GB 3200MHz CL16
Cooler: Asetek 645LT
GPU: EVGA GTX 1080Ti Black
Case: Dan Case A4
Storage: 2TB Sabrent (PCI-E 3.0) - Windows
Storage: 1TB Crucial P5 Plus (PCIE 4.0) - Fedora
Storage: 1TB Samsung 860 EVO (SATA) - Steam
nope, completely incompatible. which country? whats your budget?
