can someone help me build PC for multitasking,programming
requirements:16GB RAM,good cooling system and good processor for multitasking and SSD(250gb if possible)
price: around 1000-1100-1200 dollars
Just I don't know which parts are good enough..I mean I guess i5 8600K,16GB 2666Mhz,GTX 1060 are good ,but some parts like Motherboards,cases are so expensive and I don't know which of them are good
you can use pcpartpicker.com
https://linustechtips.com/topic/918690-help-me-build/
2 minutes ago, matus177 said:
Hey!
Sure we can. Do you plan on some kind of gaming(1080p60hz)? If it is american dollars it is a pretty huge budget for programming pc as it is not very demanding. I will try to pick up something for ya. Any preferences amd/intel?
intel,but I won't use it for gaming :D I'm from EU
https://linustechtips.com/topic/918690-help-me-build/#findComment-11263043
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.69 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($79.02 @ Amazon)
Memory: Corsair - Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory  ($156.00 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.85 @ OutletPC)
Video Card: Asus - Radeon RX 580 4GB Dual Video Card  ($289.89 @ OutletPC)
Case: Corsair - Carbide Series 88R MicroATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ SuperBiiz)
Total: $923.32
Generated by PCPartPicker 2018-04-20 12:00 EDT-0400
Added in a RX 580 instead of a 1060 6GB as it was surprisingly cheaper (and it should be better for compute tasks).
You could go with a much cheaper GPU if you do not do any kind GPU-intensive task though (multitasking is very broad).
Edited by Eibe
Changed RAM as I selected a 2666 version by mistake.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/918690-help-me-build/#findComment-11263048
there's 28 countries in the EU, and they don't exactly have the same prices for parts.
https://linustechtips.com/topic/918690-help-me-build/#findComment-11263058
6 minutes ago, sample text said:
uh,I'm from Bulgaria.I will probably purchase with Euros,but I will buy parts with USD if I have to
You would have to pay ridiculous import tax.
This is a German-based part list:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (€153.19 @ Alternate)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (€73.89 @ Amazon Deutschland)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  (€152.74 @ Amazon Deutschland)
Storage: SanDisk - Ultra 3D 500GB 2.5" Solid State Drive  (€104.63 @ Amazon Deutschland)
Storage: Hitachi - Ultrastar 7K4000 3TB 3.5" 7200RPM Internal Hard Drive  (€59.90 @ Amazon Deutschland)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  (€289.00 @ Caseking)
Case: Corsair - Carbide Series 88R MicroATX Mid Tower Case  (€46.99 @ Amazon Deutschland)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€77.38 @ Mindfactory)
Total: €957.72
Generated by PCPartPicker 2018-04-20 18:06 CEST+0200
I went with 500GB SSD and 2TB HDD as it was largely in your budget. I have also swapped out the RX 580 with a 1060 6GB as it was 20 euros cheaper. And changed the motherboard for the same reason.
Unraid Server
https://linustechtips.com/topic/918690-help-me-build/#findComment-11263074
If not gaming I would recommend amd because it outperforms intel. Try to look at sites in your country what is the pricing of these components which I listed you.
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor  ($198.69 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  ($102.19 @ OutletPC)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($123.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SSC GAMING ACX 3.0 Video Card  ($214.88 @ OutletPC)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($87.28 @ Newegg)
Total: $1031.66
Generated by PCPartPicker 2018-04-20 12:08 EDT-0400
Do not buy from usa as you would need to pay tax. If you want to buy from eu take a look at mindfactory.de. But firstly take a look in your country.
https://linustechtips.com/topic/918690-help-me-build/#findComment-11263077
