The right UPS
Go to solution Solved by factorialandha,
2 minutes ago, MrMcMuffinJr said:
the goal should be, enough time for a safe shutdown
again, this depends on the USE case. So for most people yes. however the original poster might have different plans.
As a basic guess, i would say a UPS around 1500VA should cover you for a few minutes. Effectively you want to make sure that at max load, you need your UPS to be able to handle it otherwise its just going to trip and not even try to power your device plugged into it.
The longer you want to last the larger UPS you will need, a 1500 VA at load, will probably last you around 5  minutes or so (i think)
4 minutes ago, factorialandha said:
i guess the bigger question is how long do you want it to last ?
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/917221-the-right-ups/#findComment-11247718
https://linustechtips.com/topic/917221-the-right-ups/#findComment-11247751
5 hours ago, TEGNO said:
Hello.
I have a 1050W power supply. I want to buy a UPS. My needs 860 at most. Is it ok to buy a 900W UPS? Or should I buy a 1200W? will my computer be in any danger with the 900W?
What your system specs and devices you plan to have on a UPS it only needs to be large enough for the load your applying.
https://linustechtips.com/topic/917221-the-right-ups/#findComment-11248643
On 16/04/2018 at 9:33 PM, TEGNO said:
Hello.
Eaton have a nice calculator on their site, where you can add more device and specify their pull of power...
http://upsselector.eaton.com/Calculator/Load/1435226
/Kasper
https://linustechtips.com/topic/917221-the-right-ups/#findComment-11258477
