1 minute ago, Razerlob said:
I was wondering why would EK make a kit for 400 dollars with no GPU block in it? What is the point of buying it? https://www.ekwb.com/shop/ek-kit-x360
The kit uses their top shelf components. Thats why.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/916940-ek-water-cooling/#findComment-11245053
Personally I'd recommend the P series for the D5 pump but as mentioned they're quality components. If pick and choose parts of the same caliber you get to around the same pricepoint.
https://linustechtips.com/topic/916940-ek-water-cooling/#findComment-11245068
