Hello LTT,
I got a used GTX 680 that works fine, benchmarks fine on Heaven, and has the newest drivers installed. I even stress tested my CPU, and that is working fine too. However, all of my games work for a bit and then freeze, but completely are still running, with the exception of Fortnite which just crashes. I was just playing Dota 2 for about 50 minutes and it was working fine until I went back to the menu and it froze. I've tried older drivers, clean install of windows, etc. What else can I try?
https://linustechtips.com/topic/916856-games-keep-crashing-help/
check temps with a cpu & gpu load
AMD Ryzen 5 3600 | Corsair H100i Pro | ASRock X570 Phantom Gaming 4 | Corsair Vengeance 32GB 2x16gb @ 3200mhz  | Vega 64 @ Stock | Fractal Design Define R4 | Corsair RM750
ThinkPad T480 | Intel Core i7 8650u | Nvidia MX150 | 32GB DDR4 @ 2400mhz | Samsung 840 Pro 1tb
Are you sure your overclock is 100% stable? How are your CPU temps looking while gaming?
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
1 minute ago, Savant82 said:
I've done that, they're normal.
check event viewer, post the crash information here.
Just now, Savant82 said:
They're looking normal as well.
Okay can you define "normal"? And have you done a good amount of stress testing? 4.8GHz on a 4790k is a rather high overclock even for a good chip.
3 minutes ago, Savant82 said:
That's outdated my bad. It's running at stock rn.
Ah ok.
You could try a round of Memtest86 just to rule out bad RAM. A look into Event Viewer is a good idea also as @MellowCream suggested earlier.
-Moved to Troubleshooting-
8 minutes ago, ApolloX75 said:
Ah ok.
How do I navigate through Event Viewer? The only games that truly crash are Minecraft and Fortnite, the others just freeze.
Event Viewer -> Windows Logs -> System and look for exclamation marks with timestamps corresponding to the freezes or crashes.
Edit: Can also check under Custom Views -> Administrative Events for errors as well.
Fortnite just completely froze my entire PC for over an hour, didn't crash so I couldn't look.
You can go into Event Viewer after the fact, it stores the events so you can check later.
6 minutes ago, Savant82 said:
There's so many idk which event is the right one.
Ha, it's a bit of a puzzle, I know. If you like post a screen cap of the error list with the descriptions expanded and we'll see if we can decipher it.
