I can't really help you much with this, but I doubt it is worth it. Yes there are motherboards for hardcore overclocking, but they are expensive and most likely not worth it. If money is no object they do exist, but the issue is probably with the CPU.
i5-8600k, MSI Z370-A Pro, 2x 8GB DDR4-3k, MSI Gaming X 1060, NZXT S340, 2TB HDD, 750w Corsair PSU, AOC 2775 OC'd to 80Hz and CFG73 at 144hz
Comic sans is the worst font
Check out my monitor overclocking guide
1. Yes, but you need to win the silicon lottery and delid the CPU first.
2. Increasing AVX offset causes instability as it increases the clock speed when running tasks that uses AVX instruction set. Games arent one of them, so might as well leave it alone.
LLC isnt necessary, though careful use can lower voltage at idle to save some power.
Desktop benching:
Increasing the AVX offset actually lowers the clock speed whil running AVX instruction sets.  This is very usefull to control temps during AVX use, as AVX require additional current and can heat things up significantly.  You would be surprised in some of the things that are starting to use AVX.
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
i have already won the lottery those are the specs ive ran my 8600k at after deliding, so would investing in a better board really help me maybe hit 5.4 or even 5.5 assuming thermals are okay? i havent pushed over 1.415 vcore to the chip yet either
so then is it worth it to apply something like a 2 or 3 avx offset so my clocks drop to 4.8 or 4.7 in avx? is it really just for power and thermal headroom? because i have that
Yes. I've seen M10 Apex helping loser chips that wont do 5GHz reach it. It should help the winners as well.
Of course, there are also extra options on these mobo that could potentially allow more overclock
Desktop benching:
