It is possible.  Its called a Chillbox, but you need to use a Air conditioner rather then a Refrigerator as the Fridge has a very small condensor/evaporator and just isn't meant for any significant thermal load inside its system.
Where a decent AC can handle a house with electronics and people inside it radiating heat no problem!
Here is info about Chillboxes
http://www.overclock.net/forum/133-phase-change/1533164-24-7-sub-zero-liquid-chillbox-club.html
AC Condenser inside a Cooler filled with coolant that is chilled and Pumped to the Sealed PC box inside
Then coolant is run through the components and through a Radiator in the box, THE BOX is sealed from outside air, so all moisture is frozen out of the air at the Radiator.
LL
https://linustechtips.com/topic/916266-cooling/#findComment-11239853
