I just bought a new gpu and I am connecting to my monitor using mini dp to dp.
However the headphone got no sound when connected to pc while make sound when plug into the monitor.
Previously it has sound, what did i miss here?
  • CPU
    Ryzen 7 3700x
  • Motherboard
    MSI B450M Mortar Max
  • RAM
    Klevv Bolt X 3600mhz CL18 overclocked to 3600mhz CL18 @ 1.35V. (latency 67 ns)
  • GPU
    Gigabyte Windforce GTX 1080
  • Case
    Fractal Design Define Mini C Windowed
  • Storage
    1TB HDD from Toshiba, 250 gb Samsung 850 evo, 2TB Western Digital SN750
  • PSU
    Superflower Eco Silver 600W
  • Display(s)
    Dell U2417H
  • Cooling
    Arctic freezer 34 esports duo, Arctic P12
https://linustechtips.com/topic/915978-no-audio-output/
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236551
You want to use your PC's built in audio output while using the Dell monitor. This doesn't work now, but it did before you installed the new GPU. Am I understanding you correctly?
What motherboard do you have? Looks like there's no audio drivers other than NVIDIA drivers.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236657
I want to use the headphone jack on the pc io since the monitor cannot use the mic of headphone. It did work before I used another gpu from other brand.
My motherboard is asus h110m k
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236667
Try to download and install the audio drivers for the motherboard again. If that doesn't work, I'm clueless.
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236684
from asus website? I am downloading realtek audio driver from the website.
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236688
Yes. Let us know how that works out. It is strange that the motherboard outputs have disappeared from Windows. If reinstalling drivers doesn't work, maybe there are some BIOS settings you could try. I know you can disable motherboard audio I/O in certain BIOSes, perhaps you can reenable them?
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236694
How did it work out?
Also, while searching for something else I stumbled upon this:
Basically it says "show deactivated devices" and "show unplugged devices". If one of these are unchecked, some options disappear. Maybe that's what has happened?
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11236810
I checked both of them, all they showed are the one listed on post2
Still the same :(
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11237006
Just reinstalled window10, nothing changed :(
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11238942
I installed
I installed realtek audio driver from asus but it didnt appear on the device manager tho
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11239091
https://www.techspot.com/community/topics/cannot-find-realtek-in-my-device-manager.188563/
Sorry for my bad english but his situation is exactly the same what happen to mine.
I tried all the solution given but still cant make it work
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/915978-no-audio-output/#findComment-11239270
