So my question is how do i completely stop and return my computer back to normal after using driver verifier? Do I select delete existing settings, and reboot pc and im good to go? everything is back to normal how it was before i did verifier? Sorry for the noob question figured i would as you dudes. Please help haha
https://linustechtips.com/topic/915239-question-about-verifier/
To stop or reset Driver Verifier
  1. Open a Command Prompt window (Run as administrator) and type verifier to open the Driver Verifier Manager.
  2. Select Delete existing settings.
  3. Reboot the computer.
Or type the following command in a Command Prompt window and reboot the computer.
verifier /reset
source: https://docs.microsoft.com/en-us/windows-hardware/drivers/devtest/driver-verifier
https://linustechtips.com/topic/915239-question-about-verifier/#findComment-11229953
