A stupid problem I have.
Go to solution Solved by xTorchii,
I ran a monitor test, and have noticed that the problem is slowly but surely fixing itself and reverting back to normal. I don't understand how this works and I'm just going to avoid using this PS2 HDMI solution on my monitor. Thanks for a bit of information.
I have an Asus VX24AH monitor that I've had for over half a year now. I primarily use it for my PC, however occasionally switch over to a PS4 or in this case a PS2 using a component to HDMI solution. When I switch back to PC, I realise that my monitor now has a flickering ghost image from the PS2 start menu that is visible on certain colours on my screen.
Does anybody have any idea what caused this and how I can either revert this or stop it from getting worse?
https://linustechtips.com/topic/914911-a-stupid-problem-i-have/
If it's a CRT, that is burn-in and it's permanent. It's caused by displaying a static image for too long, it's what screen savers were designed to avoid.
If it's an lcd it should go back to normal by itself.
sudo chmod -R 000 /*
https://linustechtips.com/topic/914911-a-stupid-problem-i-have/#findComment-11226210
https://linustechtips.com/topic/914911-a-stupid-problem-i-have/#findComment-11226225
The flickering part tells me that its likely not traditional burn in.  The adapter may be doing something with the signal that the display controller is not expecting or does not like, causing memory corruption.  Yes, your monitor likely has memory inside it.
https://linustechtips.com/topic/914911-a-stupid-problem-i-have/#findComment-11226237
