11 minutes ago, fangirl1234 said:
What would you recommend to use to water cool a EVGA gtx 1060 6gb SC? I want to find a full water block for it, but i cannot find one that says it will support that size of 1060. Should I just go with a alpha cool solo?
For a card like a 1060 it doesn't really need watercooling as it doesn't generate a huge amount of heat. There may be full cover blocks from brands overseas such as Barrow but other than that your only option would be to go with an AIO watercooler and GPU adapter or a universal block.
https://linustechtips.com/topic/914832-water-cooling-help/#findComment-11225330
thank you, ill just use a universal, and the full size block that i was thinking of was the alphacool upgrade kit for the solo, cause they make on perfectly sized for the 1060, and yeah, but my card has only one fan on it so when playing games it reaches a pretty toasty 80c
https://linustechtips.com/topic/914832-water-cooling-help/#findComment-11225971
