Check cable connection
Go to solution Solved by Joel Wealands,
Solution to my problem was replacing the ram, and putting a hard drive that already had windows installed.
I've been trouble shooting this laptop for the past few weeks starting it up in safe mode checking absolutely everything, and I can't seem to figure out the issue with this acer laptop as it was dropped by my brother I'm assuming it's a motherboard issue of some sort. Please help me!
https://linustechtips.com/topic/914522-check-cable-connection/
Okay I'll give some back story, this ssd was in my old laptop that's power button broke so I moved it to this laptop that had been dropped I've tested the ssd inside this other laptop still gets recognised I honestly think it might be a windows problem since it was a windows 10 ssd to begin with and I put a cd in to fix windows 7. Im not sure what I should do.
https://linustechtips.com/topic/914522-check-cable-connection/#findComment-11222359
Uhm I've tried using multiple hard drives inside it but non of them worked, I've attempted to use them in another pc, also ran diagnostics on my friends computer that was holding the files inside of the ssd and you could access them but it wasn't a bootable drive.
https://linustechtips.com/topic/914522-check-cable-connection/#findComment-11222393
