Wireless vs wired
By
Carnage1
in Peripherals
in Peripherals
Solved by wirs,
The pad just improves your quality of life. If you choose to use the mouse in wireless mode you will have to charge it every few days unless you get the pad.
And yes it's a better value than the Razer counterpart. The mamba hyperflux has no battery and will only work when paired with the mousepad or being wired. The mousepad is kinda bulky and the whole set looks kinda cheap.
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
