Im building a computer and im wondering if the i7-8700k is compatible with the ASUS Prime B250-PRO. Ive seen that the motherboard is compatible with the 7th generation but is it with the 8th? I know that they are both 14 nm but i dont know if theres a problem .If there is a problem, please recommend one that is compatible.
https://linustechtips.com/topic/910472-i-need-help-with-compatibility/
No that motherboard isn't compatible with that CPU, I recommend you go for the Asus Prime Z370-A.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
8th gen Intel CPUs need a 300 series chipset. As of right now, only the Z370 chipset is actually available (and you'd want the Z chipset with a K SKU CPU anyway).
The 8700K uses the same socket as 7th gen, so they're physically compatible, but they're not electrically compatible (or rather, they kind of are, but they don't work with 100 or 200 series chipsets.
