I have a Ryzen 5 1600 hosted in the S340 Elite.
I really like the X62 cooler(I want more oc and my build to look a bit better)
The X62 is 170E(Greek Price) and the X52 is like 140E(Also Greek Price)
I am a bit short on budget at the time being tho so thats why i though of the X52 AIO at first.
What shall I get?(Will get an upgrade on CPU in about a year)
https://linustechtips.com/topic/910400-aio-question/
Don't think there is too much of a difference in performance between the two, maybe one or two degrees. With the x62 being a larger radiator you could run the fans slower for an even quieter system, but if you don't mind too much the x52 is a fine choice.
Any other questions or comments just @Hyp3rion and I'll try to reply.
Tot gauw
https://linustechtips.com/topic/910400-aio-question/#findComment-11183098
