I'm trying to install this DLL file but it says I don't have access to my SYSWOW64 folder, but I'm the only user on my PC so I should be admin. I tried going into security properties but everything is greyed out and I can't change it.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/908353-help-with-dll-files/
What is the DLL file? Are you trying to install just the file itself? If so its not a good idea to download a DLL file and try to install it. Depending on the file, it will be attached to something like "DirectX" or "Visual C++ 2010, 2012, 2013" etc...
Main Rig
CPU: Intel Core i7 920 @ 4.0GHz
Motherboard: ASUS P6T SE
RAM: 10GB OCZ DDR3 (Triple Channel) @ 1600MHz
GPU: NVIDIA GeForce GTX 770 2GB
Case: Antec GX500 Window
Storage: 2 x 500GB Samsung 7200RPM HDD
PSU: Coolmax 1200W ATX 80 PLUS GOLD
Cooling: DEEPCOOL GAMMAXX 300
Teamwolf Mechanical Gaming KeyboardASUS ROG GX850 Laser Mouse
Main Laptop
Alienware 17 (2014)
(Intel Core i7 4710mq @ 2.5GHz - 3.5Ghz (Turbo) | 16GB DDR3 RAM | 4GB AMD m290x Dedicated Graphics - 1TB SSHD)
XP Machine (build in progress...)
CPU: AMD Athlon 64 3000+ @ 1.8GHz
Motherboard: DFI LANPARTY NF4
RAM: 1GB OCZ DDR (Dual Channel) @ 400MHz
GPU: NVIDIA GeForce GT610 2GB Synergy Edition
PSU: BFG 450W
Apple iMac (2009)
CPU: Intel Core2Duo @ 2.66GHz
RAM: 6GB DDR3 @ 1333MHz
GPU: NVIDIA GeForce 9400 256MB
RetroPie Machine (Linux Mint & RetroPie)
CPU: Intel Core2Duo @ 3.0GHz
RAM: 7GB DDR2 @ 800MHz
GPU: AMD Radeon HD 3650
https://linustechtips.com/topic/908353-help-with-dll-files/#findComment-11163520
Maybe my direct X needs updated then because its dxgi.dll and thats tied into direct x
CPU
https://linustechtips.com/topic/908353-help-with-dll-files/#findComment-11165422
