My PC Keeps getting a bsod and I cant seem to fix it. (FX 6100 CPU, GT 640, biostar a960 version 6.1 motherboard.) newest graphics drivers.
The BSOD is "Memory_Management" The Cached memory in task manager goes up and up instantly as soon as I log into windows (Crashes at 9gb) (i have 16gb in)
I really dont know what im suppose to be doing now.. I tried resetting windows, restoring, While doing either the computer just turns off.
https://linustechtips.com/topic/906645-please-help-c-bsod-memory_management/
Sounds like you have a memory leak from a program you have running. This would be the only reason why your memory usage would continually go up and up and up until it crashes. Find out which program it is by watching the process tab and see whats using up the RAM and get rid of that program.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
I had everything off and it was still happening.. The only programs I have open is discord and chrome. Even if I didnt have anything running since the start it still happens. I dont get it
Ok well its probably Chrome, Discord, or a background app then.
Run a GOOD antivirus scan such as Avast Free's boot-time scan. Make sure under settings you have potentially unwanted programs (PUPs) selected.
Then just sot back and wait.
Top-Tier Air-Cooled Gaming PC
Current Build Thread:
this didnt happen 3 days ago, I updated my drivers, idk what happened but I cant even go back on them. and I got a new monitor (S2417DG) but still this shouldnt be crashing
We are telling you what the problem is. You have a memory leak.... You seem more eager to disprove us than test and report back what we suggest. Kind of counter productive when you come to us for help.
Community Standards
"Beast Mode"
Sorry I did not to mean it like that. I was trying to just get all the information out that I could cause it didn’t happen before. Is there a way to test what program is causing it? Or should I just not open them and see if the cache goes up and up like it was?
Only way is to watch task manager and what is using your Memory.
Community Standards
"Beast Mode"
