i recently put an EK 1080 FTW block on my EVGA FTW card and my temps are horrendous. Idle is fine about 35 degrees but as soon as the GPU core ramps up the temps spike 30c. under full load its hitting almost 100c. Anything will help, i have re-seated the GPU to the block 3 times now with the same result every time.
https://linustechtips.com/topic/906511-1080-temp-issues/
Well something aint right, sounds like something is stopping the block from seating on the GPU correctly, take it off and start again, check for any screws that shouldn't be there and see if your paste is spreading for evidence of contact. How are CPU temps?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/906511-1080-temp-issues/#findComment-11145314
Are you absolutely sure the waterblock is tightened down properly?
Also, I saw no mention of a loop in your post, are you running the waterblock without anything connected to it?
-Moved to Troubleshooting-
https://linustechtips.com/topic/906511-1080-temp-issues/#findComment-11145363
