i have a lenovo y720 cube with these specs
Processor
Intel Core i5-7400 Processor ( 3.00GHz 2400MHz 6MB )
Operativsystem
Windows 10 Home 64
Totalt minne
16.0GB PC4-2400 DDR4 UDIMM 2400MHz
Storage
1TB 7200 +128GB SSD SATA III
Warranty
Two year Depot or Carry-in
Graphics
NVIDIA GeForce GTX 1070 8GB GDDR5
when i launch almost any game the cpu goes to 100% and stays there
and on simple workloads like browsing the web its at about 30-50%
also after 1 hour or so the backplate and the cables are really hot this is in an open room with good airflow so it became even worse when i moved my setup
is there anything i can do with this? upgrade the cooling? if so what do you guys recomend   its a really compact case
link to the pc: https://www3.lenovo.com/no/no/desktops-and-all-in-ones/gaming/y700-/Y720-Cube/p/99IC9Y20274
https://linustechtips.com/topic/906393-cpu-running-100/
Ran a virusscanner yet? Friend of mine had the same problem-ish, but later found out his PC was loaded with malware and virusses.
Check taskmanager to see which programs are using up so much of your CPU.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/906393-cpu-running-100/#findComment-11144043
Nice looking case.  :)
But on the serious front -- the first thing of concern is that the CPU is running at or near 100% for your games.  That's a bit much.  As stated above -- it could be a virus or malware that is causing the issue.  Take a look through your Task Manager to see whats eating up all that CPU usage.  (Under details see what is using the CPU)
If its a hardware issue then you could be in a bit more of hot water -- I doubt that the system is designed to run as hot as you describe.
Take a quick look inside your case as well -- make sure all the FANS are spinning and nothing is "stuck" or full of debris.  A fresh install of Windows is not a bad idea either.
https://linustechtips.com/topic/906393-cpu-running-100/#findComment-11144094
