You would have to be more specific in what you need. But if you're asking if the 670 would go well with the board the answer is yes and always yes. Just make sure you have power supply that has enough wattage to power the 670. A 600w power supply would be enough. Besides that what other suggestions do you need
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/906-need-input/#findComment-11533
Having an Ivy Bridge (3rd Gen CPU) will also be beneficial to having a 670, but yes, please fill us in on the rest of your build and budget.
i5-3570k 4.0 GHz, Asrock Extreme4, Corsair HX850, EVGA GTX 670 2GB, 8GB Corsair Dominator RAM, 1TB HDD, CM HAF 922
Steam: OG Washington | Xbox Live: AnAwesomePosum | Battlelog: AnAwesomePosum
https://linustechtips.com/topic/906-need-input/#findComment-11559
Everything fits. if it hase a PCIe interface, it will work.
and nothing works better then something else, unless you take a 680 or 7970. but that will be obvious :P
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
https://linustechtips.com/topic/906-need-input/#findComment-11565
Sorry for not including everything else, I am new to this. So here is the full build so far:
Case: Corsair Vengeance C70 (bought)
CPU: i7 3770k (bought)
Mobo: Maximus V Forumla
Graphics: eVGA GTX 670
I need some help with RAM and power supply. For power supply I was thinking about getting a 800-850 watt. As for my budget any changes would need to be close to the same price as to what I was looking at. Help is appreciated, thanks guys.
https://linustechtips.com/topic/906-need-input/#findComment-11647
Well if you're just going to use your computer for just gaming and other less RAM intense applications then a 8 GB kit will do you fine. I recommend G.SKILL Snipers or CORSAIR Vengeance.
On the other hand if you're going to be running multiple VMs then you'll probably needs somewhere around 16 GB to 32 GB depending on how intense you set those VMs to be.
https://linustechtips.com/topic/906-need-input/#findComment-12296
