    Windows 7 Ultimate 64-bit SP1
CPU
    Intel Core i3 540 @ 3.07GHz    40 °C
    Clarkdale 32nm Technology
RAM
    6.00GB Dual-Channel DDR3 @ 664MHz (9-9-9-24)
Motherboard
    ECS H55H-M (CPU 1)    22 °C
Graphics
    SDM-E76D (1280x1024@60Hz)
    4095MB NVIDIA GeForce GTX 1050 Ti (Gigabyte)    34 °C
Storage
    149GB Seagate ST3160811AS ATA Device (SATA)    43 °C
    74GB Seagate ST380815AS ATA Device (SATA)    46 °C
    149GB Seagate ST3160811AS ATA Device (SATA)    42 °C
Optical Drives
    ATAPI DVD A DH20A3S ATA Device
Audio
    NVIDIA High Definition Audio
https://linustechtips.com/topic/905750-upgrade-help-plz/
What is your budget? Do you have a good power supply? Is this a pre built?
Tech, engineering, gaming and promoting the metric system. These are my things.
Lover of Linux.
Currently rocking a ThinkPad L13 laptop tricked out with an i7, running Windows 10.
PC Specs:
CPU: Intel i7 6700
GPU: Nvidia GTX 1070
Motherboard: Asus Z170 A
RAM: Corsair Vengence 16GB
https://linustechtips.com/topic/905750-upgrade-help-plz/#findComment-11137781
CPU: i7 860/870/875/880 are all viable. I dont know whether Xeon using the same socket works, but ECS doesnt list them out as compatible so I'll let someone else confirm it. If it does support Xeon, then X34xx ones are the best options.
Any SSD/HDD?
Desktop benching:
https://linustechtips.com/topic/905750-upgrade-help-plz/#findComment-11137785
The monitor for sure.
i7 12700k @ 5.1GHz OC (EKWB) / Msi Edge wifi ddr4 / Asus TUF 3080ti (EKWB) / Acer XB327 270HZ, 3x LG 27GL83A-B 144hz, SONY KDL40D3000 Thermaltake P5 / 32gb Corsair Dominator Platinum 3600 / Samsung 980 pro 1tb NVMe ssd, Serbrent 1tb NVMe ssd,Samsung 850 EVO 500GB, Samsung 860 PRO SSD (raid), 2 TB Seagate HDDSeasonic TX 1000w titanium/ EK-FC1080 Ti GTX ASUS Strix RGB GPU Block, EK-Supremacy EVO, EK-CoolStream XE 360 [6x120 Thermaltake Ring fans], EK-CoolStream XE 360 slim [6x120 Thermaltake Ring fans],  EK-DDC 3.2 PWM Elite Edition, EK-RES X3 250 RGBMountain Everest custom with Sorbothane sound dampening / Razer Viper Ultimate, Logitec G502 , Logitec G Pro Wireless / Beardynamic DT1990 PRO with Litz wire full conversion to balanced, custom cable in Litz, Dakoni ear pads going through Topping E30 DAC to Singxer SA-1 amp/Sennhieser HD598, Sennhieser GSP 670, Custom Floor Standing Speakers in 5.1, Panasonic amp. Rode NT-USB on Rode boom.
https://linustechtips.com/topic/905750-upgrade-help-plz/#findComment-11137822
