I bought this monitor off Ebay for a really good price just for a faster refresh rate but i cannot run the screen how it should be ran.
I use a R9 Fury + DVI D dual link cable supplied by the seller which is used.
Windows 10 64 bit, there is no drivers for this screen and i have found no .inf files anywhere to download for it.
It is stuck at 640x480 with res changed greyed out in Windows. I tried to use CRU to use native res + 120hz, it works only when my 60hz panel is connected as an extended screen, and then the 120hz panel completely ejects it's self from device manager after around 3 minutes, once it does this it loses signal in a split second showing the image for that time.
Any help would be wonderful thank you.
Intel Xeon E5640 4510mhz 1.10v-1.42v (offset) - C states on (◣_◢) 16GB 2x4 1x8 1296mhz CL7 (◣_◢) ASUS P6X58DE (◣_◢) Radeon R9 Fury Sapphire Nitro (◣_◢) 500GB HDD x2 1TB HDD x2 (RAID) Intel 480GB SSD (◣_◢) NZXT S340 (◣_◢) 130hz VS VX2268WM
https://linustechtips.com/topic/903495-viewsonic-vx2268wm-help/
Are you using a dvi d link cable or hdmi or displayport
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/903495-viewsonic-vx2268wm-help/#findComment-11115947
A used DVI-D if it helps i have ordered a HDMI - DVI-D cable to see if the R9 picks that up.
https://linustechtips.com/topic/903495-viewsonic-vx2268wm-help/#findComment-11115949
