hello
 I want to replace Corsair Hydro Series H100i V2 Extreme Performance Liquid CPU Cooler  stock fans. I want to replace with corsair  LED fan to have some color . I don't know which one is good. stock fans have 4 pin . I can't  find which corsair led fans have 4 pin. I'm found this Corsair Air Series AF120 LED Red Quiet Edition Twin Pack and Corsair Air Series SP120 LED Red High Static Pressure Fan - Twin Pack both day have 3pin. can I connect this to 4 pin stock fan connector. I want silent, quiet fans
Thank you
https://linustechtips.com/topic/903046-question-fans-for-liquid-cooling/
I have the HD120 RGBs and they look sick and have much air pressure. Get them ;)
|| CPU: I7 6950X @4.6 (1.35V) || Cooler: CUSTOM EK LOOP || Motherboard: ASUS RAMPAGE V EDITION 10
|| GPU: 2x Vega 64 Strix OC @1762 / 1100 MHz || Memory: 16GB G.Skill Royal RGB 3200 Mhz ||
HDD: Segate Barracuda 3TB || SSD: Samsung 970 Evo 512 GB || PSU: Corsair HX 1200 W || Case: Fractal Design Define R6 Gunmetal || Fans: Corsair HD120 (x4) / BeQuiet Silent Wings 3 (x4) || Monitor: ACER XF27HU ||
Second Monitor: BENQ RL2455HM || Mouse: Logitech G502 Pretus Core || Keyboard: Logitech G810 Orion Spectrum || Headphones: Sennheiser IE80 ||
        Buildlog expirience swapping to x99:
Just now, ZEKENZY said:
is it 1 fan have 2 wire. 1 connect to fan pump. but other wire. where you connect it .
To a RGB controller.
Here is one with an included Controller. I suggest you to buy the 3 pack for 75 Dollars:
https://www.newegg.com/global/de/Product/Product.aspx?item=N82E16835181119
with that controller , Can I adjust RGB color from software cosair link ?
