Best Fans for Radiators
Solved by Skiiwee29,
I love my Notcua NF-F12 Industrial PPC 2000 RPM fans on my radiator. I feel they are better than the EK Vardar fans that came with my EK Radiator. They have a lower pitched motor noise compared to the Vardar IMO. As far as 140mm fans go, The Noctua NF-A14s are a decent choice as is the Corsair ML series fans. Sadly, there is an appreciable loss of Static Pressure the larger the fan. But generally the NF-A14 and Corsair ML will probably be th e best.
